Cognitive battery
Please select one of the seven tasks provided below to test our material. We request you to ensure that the diagonal measurement of your monitor is set properly. Currently, it is set to 33 centimeters, however, you may adjust it by clicking on the parameter icon located on the top right corner. Please note that this work is available for free access at Github repository. Additionally, the paper studying the material can also be accessed at Cognitive Test Battery - Frontiers
Multi-object tracking training
Choose one of the available training tasks. Before proceeding, please ensure that your screen parameters have been correctly set by utilizing the parameter icon located in the top right corner. The first task, MOT_zpdes, is a training session that utilizes the ZPDES algorithm to manage the level of difficulty. The second task employs a staircase algorithm to manage the difficulty progression. The algorithm incrementally increases all sub-parameters (speed, distance, tracking and probe duration) simultaneously and then increases the number of targets when the maximum of the sub-parameters is reached. The third task utilizes a variant of the staircase algorithm, which incrementally increases each of the sub-parameters iteratively. Lastly, the third task is a session that combines the usage of the ZPDES algorithm and a panel that enables the control of various hyperparameters.
